Dale_Traveling
Sep 16, 2016Explorer II
Ductape wrote:Same experience with the same size tires but I air to 85. I played around increasing pressure. Once I hit 90-95 PSI it took a lot of concentration just to keep the coach in the lane on calm days in addition to the increasingly harsh ride of over inflated tires.
Have you weighed it?
I have experimented with pressures from 75 to 100 and get the most stability at 80. Same tire size. Load inflation chart says 75 for my weight.
Lower pressure it slows the response to steering inputs. Higher gets more reactive to road imperfections and skittish as the contact patch shrinks.
YMMV
What has helped the most for me was adding a rear track bar in addition to the CHF of the Ford chassis. I still get pushed some during heavy wind events but the steering response to such and the speed coach reacts to steering inputs has improved greatly. I get little if any movement from passing vehicles.
The geometry of various rigs (wheel base to overall coach length), loading and balance of the load, towing, road conditions and such may effect how coach A drives as compared to coach B. In other words what worked for me might not solve your problem or concern.
38,782 PostsLatest Activity: Sep 10, 2026
