Santaflow
Oct 16, 2020Explorer
gbopp wrote:
Do you have low flow from the hot or cold side of your faucet, or both sides?
Did you unscrew the end of the faucet where the water comes out and clean the screen?
Did you look under the sink while the water is running to look for leaks?
Hello,
I checked under the sink and the pipes from there to underfloor are ok. Also the pipes from the water pump to underfloor are also ok.
The car is a big sur 225. There is any way to know the planes of the chasis?? So I can know how to access to the plumbing.
Thanks
