Executive45
Oct 21, 2020Explorer III
Kinda, sorta, depends. If the rear is level as it should be, and the leveling isn't too severe, then you'd most likely be ok. Remember you'll have this big honking machine attached to the rear of the coach. It's designed to swivel as you hit bumps and dips in the road. Furthermore your coach's suspension lessens the stress on the hitch. That said, your stabilizing jacks are only designed to level the coach and only to a certain degree. You're going to add additional stress to your jacks by not unhitching. How much stress is too much? Can't answer that. Depends on your tow system, depends on how severe the out of level site is, depends on the jack system you're using and how well you've maintained it. I had one blow on me once...what an ugly mess. Scared the **** out of me and two of my neighbors too. I wouldn't do it as a matter of practice, but once in awhile and you might get away with it. Just remember, you're adding extra stress on your system by being lazy. You only have to "release" the hitch....Dennis
38,783 PostsLatest Activity: Sep 23, 2026
