- VA-ApraisrExplorer IIYep.....that's about all we do is boondock on beaches/islands, but 400watts of solar, 2-100amp BattleBorns, plus generator keeps everything A-OK!
- rhagfoExplorer III
VA-Apraisr wrote:
Direct replacement which is propane/electric. He has BattleBorn lithium's like I do but don't need to run it off 12v. Generator available if propane acts up.
I asked as the beauty of the 12 volt compressor unit is better cooling. If you boondock a lot, then it is an additional draw on the batteries. - VA-ApraisrExplorer IIDirect replacement which is propane/electric. He has BattleBorn lithium's like I do but don't need to run it off 12v. Generator available if propane acts up.
VA-Apraisr wrote:
He used the link to order the factory coil pack. Severe rust occurred from beach use and then sitting way too long between uses; the rusted coils broke while driving, so, remove old and install replacement (yet to be done but this is the best solution).
Did he go with a replacement gas/electric cooling unit, or did he opt for a 12 volt compressor unit? - Make sure you clean back of unit good. Chemical reactions can cause other components to fail.
- VA-ApraisrExplorer IIHe used the link to order the factory coil pack. Severe rust occurred from beach use and then sitting way too long between uses; the rusted coils broke while driving, so, remove old and install replacement (yet to be done but this is the best solution).
VA-Apraisr wrote:
Thanks ALL for your assistance and especially the LINKS.....my brother found what is needed. This is still the BEST website for help because of ALL OF YOU!!!
What was his solution? - VA-ApraisrExplorer IIThanks ALL for your assistance and especially the LINKS.....my brother found what is needed. This is still the BEST website for help because of ALL OF YOU!!!
- Complete replacement 1RM 2652
