dougrainer
Mar 22, 2017Nomad
You just joined. You need to give a LOT more info.
Year Model of RV
Model number of Roof AC unit
TYPE tstat. Dometic has numerous models that have different fusing parameters
Turn OFF spell check. I assume you mean DOMETIC, not Domestic.
It takes 12 volt power to run the Furnace and AC control tstat system.
There is a supply 12 volt fuse usually at your main Coach 12 volt fuse panel and then there is a 3 to 5 amp fuse on the roof AC control boards.
You need to answer these questions to get any help. Douig
Year Model of RV
38,782 PostsLatest Activity: Sep 10, 2026
