PUCampin
Aug 31, 2015Explorer
Do you have a circulating fan of some type inside? When loaded with stuff you will not get much natural convection past the cooling fins inside, and even a small circulating fan will improve things. I have a computer fan wired into the hot side of the light switch so it runs as long as the fridge is on. It helps cool down faster and returning to cool after opening, it uses very little power and is one of the best mods I have done. Even in summer temps here in the SoCal desert it will maintain in the safe zone for food on propane, which puts out more btu than the electric heater thus more effective.
Check and be sure the fridge is properly baffled by looking up from the outside panel. There should be only around an inch of space between the coils and the wall to create the chimney effect. If not, you will need to fill it somehow.
38,766 PostsLatest Activity: Jan 10, 2026
