dougrainer
May 29, 2018Nomad
You will have no problem. It is ALL plug and play. I would get the 15k(HE) Penguin Heat Pumps. You will need the 10 button CCC tstat and the existing wiring is identical for connections at each HP and at the Wall tstat. ALL you have to do, is set to Zone 2 on the rear HP and set the Furnace on the Zone 1 HP control board. EACH Penguin comes with the control board(10 button) already installed. Doug
38,778 PostsLatest Activity: Jun 05, 2026
