gfs1943
May 30, 2018Explorer
dougrainer wrote:
You will have no problem. It is ALL plug and play. I would get the 15k(HE) Penguin Heat Pumps. You will need the 10 button CCC tstat and the existing wiring is identical for connections at each HP and at the Wall tstat. ALL you have to do, is set to Zone 2 on the rear HP and set the Furnace on the Zone 1 HP control board. EACH Penguin comes with the control board(10 button) already installed. Doug
Doug, is there any problem replacing existing 13.5k with 15k units? My coach has two 13.5 units, and I haven't had any issues with them, but with temperatures getting hotter than normal, I wonder if 15k units would be better? Thanks.
38,778 PostsLatest Activity: Jun 05, 2026
