TonyCarri76
Jun 22, 2020Explorer
Ok so what i did is swap the ac unit ...I have 2, so when i hooked up the other unit it turned on and no EE code. It has been working just fine up until yesterday when i turned the unit on and 1 hr later the unit turned off and so i set the temp to 65 to see if it would turn on and nothing. So I came home from work and turned the Tstat off and I got the EE code. So i just turned the unit off and tripped the breaker to see if I can reset the system this way. The communication phone wire is fine and there is 12dcv because the Tstat turns on just the EE code . Hopefully this board didn't go bad
38,782 PostsLatest Activity: Sep 02, 2026
