hairbrain wrote:
Thanks Effy,
Camping World has recommended the fan. I just don't know what changed a couple months ago when this started. So, what controls the temp of frig and where is it located. I have a feeling it is in the circuit board. It doesn't seem to matter what setting I put it on the temp is the same, so something isn't working the way it used to??
It is not the circuit board. The Temp Thermister controls it. IF it is installed on the fins and you do freeze on temp 1, then replace the thermister. The inside temp of a RV refer will be 10 degrees warmer than the fin temp-----refer at 33 degrees, the fin temp will be 23 degrees. The thermister does NOT react to the actual air temp but the fin temp. Doug
