Old-Biscuit
Oct 21, 2014Explorer III
Is RV parked 'level'?
Are the control panels lights ON/working?
If yes.....fuse(s) are OK
If no.....could be main fuse in DC Dist Panel (where other fuses are) is bad OR the 3A fuse on fridge control module is bad (outside compartment)
Do you have any other error codes (other than the '60' which indicates temp out of range)?
Have you run/used the diagnostic function to try and pin point issue?
