JimM68
Dec 13, 2013Explorer
door latches?
there are several cabinets in our motorhome that the latches just don't get the job done. Twice over the past three years, we've had corel dishes shattering on the tile floor, and every trip the cabin...
Gjac wrote:
If I understand your latch set up what I would do is screw one portion to the door and use double back tape on the cabinet side off the latch. Trim the tape and outline the holes on the tape to be used as a template to drill later. Prior to applying the tape to the backside of the latch rub a small amount of cream or oil on your finger and rub on latch when you close the door tightly the tape will stick to the cabinet and come off the latch allowing you to drill your 2 attach holes through the tape within 1/32 on an inch.
