wa8yxm
May 29, 2015Explorer III
If it is a tri-mark then I need to know if the deadbolt is set or just the striker bolt.
on th striker bolt the weakest point is the highest stress point (Excellent design) and it will break.. When this happens the handle can no longer retract the striker bolt.
Using a mechanic's seal pic.. I used the "L" shaped one.. I was able to depress the bolt without doing MAJOR damage to the RV and open the door.. Then replace the lock
If you pull the parts carefully a machinest can make you one out of STEEL.. Much stronger.
