ferndaleflyer
Jul 27, 2019Explorer III
Ok, been home a few days and fixed it. The end attached to the door frame must have had a pin in it to attach to the arm. Had a hole in the piece attached to the door frame and a hole in the arm. So, I removed the piece from the door frame, cut the head off of a bolt the proper size, welded it into the hole in the piece that mounts in the door frame, distorted the threads so nut would not come off, (I hope) and attached it to the arm on the door with a nut. It seems to work perfect and I see no reason that it won't last.
38,766 PostsLatest Activity: Jan 10, 2026
