CJOnTheRoad's avatar
CJOnTheRoad
Door Won’t Open
We have a 2005 Beaver Monterey and just came back from having our door handle and locks replaced at Beaver Motor Coach Sales. After only a handful of uses it is now not working and we can’t get into the motor home. The door wasn’t locked but it won’t open and the paddle handle is very loose. All windows are locked up. I searched online for a damage-free way of getting inside and could only find one old forum query from 2010 (posted by Rhyph) on the exact same issue. It can no longer be accessed through the forum however and the solution used was apparently sent in a PM. I suspect it may have something to do with opening the emergency window from the outside(?) All other suggestions involved drilling, locksmiths or removing the skylight and the poster commented that it was done both by themself and damage free.
Any suggestions? We are new to Class A’s and the forum. The emergency window is the bedroom horizontal slider with hinge on top, and inside has the slider latch and two red lever latches on either side.
Thanks,
CJ
  • On some window latches like mine you can drill a small hole and then use a nail to move the latch. A no damage solution. Some have done this as a backup emergency entrance solution.
  • I'd phone Beaver Motor Coach and make them pay for a service call. I suggest you join IRV2 Monaco Forum as there is all sorts of help on adjusting the linkage once you get into the coach. Sounds like some of the linkage has come apart or loose. Ask there and you will likely find a solution. Good luck, Don.
  • I did try that and tried locking with the fob and unlocking all while pushing the door in. No luck. When I try to lock with the fob it certainly doesn’t sound like it did when it was working. A more abrupt click.
  • Can you push in on the door some and just maybe???
  • Thanks but it’s parked on our paved driveway, which is pretty flat. At this point I wish it wasn’t and that was the solution.
  • Try leveling the RV, the door may be binding -- not the door latch problem
