DKLilly67's avatar
DKLilly67
Doris is Dead!
Hello all- I sure hope you can help me! We have a huge problem. We are in the middle of a trip, and our youngest daughter ( we became guardians at age 50 because the girls were being abused) in one of her episodes - tried to turn on the A/C units both at the same time by rapidly dragging the levers up and down thru all settings four times before I could get to her. My husband and I are both disabled - he is 70 I am 60. Anyways, when she did that everything went black. No power to anything. I assumed we tripped a breaker, so we reset everything. It didn’t work so I repeated it several times( definition of insanity) then I tried unplugging the autoformer from shore power waiting a bit and rebooking everything up. Back inside I turned on each breaker . For some reason everything was back. I went thru the coach and put all the unused lights in off position. I made sure anything not in use but plugged in was not plugged in.
We had lights and air again fridge was working- world was back to normal.
Then after several hours - blammo- everything out. We were able to restore power to our not shore side - but outlets are out a/c is out everything is out. We tested and found that we were getting power to the two gfci outlets but plugging anything in got nothing to turn on. So we replaced the two gfci. Well we thought we did. Turns out if you have your adult son do it and he does it backwards they will never work. So we got up this morning and the entire coach was dead. Had to call roadside assist to jump the battery.
I am lost. I have no idea what we should do now. I’m in tears. I just have no clue what I’m missing. Please anyone - if you can help me figure his out- I’m desperate.
  • Sorry to hear of your problems. However, we need to know so much more. What kind of coach and is it a 30 amp or 50 amp coach? What are you plugged into (home, campground, 15amp, 30amp, 50amp)? Have to connected the power without the autoformer in the loop? You said you had power at an interior plug but if you plug something in it will not work? Is that correct? I know you are typing and thinking fast but if you could slow down and give us some usable details it would help us try to help you.
