garyemunson wrote:
Just my 2 cents on double pane windows. We camp year 'round and in cold weather, double pane makes a huge difference in condensation (motorhomes are so closed up humidity goes up and a cold window will condense water or frost over). People who store their RVs all winter (and there are many) won't see any real advantage to double pane but will have to deal with the issue of eventually resealing them. Your preferred way of camping should dictate your window choice. I would think if they say 1/4 inch, that is going to be single pane. If you see tilt out windows, that's single. All double pane I have seen have been sliders.
!/4" is the typical thickness of the spacer between the 2 panes of glass in a slider double pane window. Our MH also has tilt out windows in the bedroom that are also thermo pane or double pane. They have a smaller spacer, don't remember for sure but either 3/16" or 1/8". If the tilt out window sits on the outside of the frame then it's going to be single pane. If it sits done inside the frame when closed then it could be double pane. We had a Fleetwood Bounder and it had double pane windows, can't say for sure that Fleetwood uses double panes in all their MHs.
