BigMac
Jan 06, 2021Explorer
Bill.Satellite wrote:
Yes it is with a bath and 1/2 setup. You likely have 4 dump valves as well but only 2 outlet ports. You can make the dump routine a bit easier by adding a "Y" connection in your hoses so only 1 line has to run to the dump station.
I had a bath and 1/2 on my 2004 Georgetown with 2-black/2-grey, 4-handles and 2-outlets. Also 2-black tank flush connections. I actually found it was simpler and more efficient to use a single outlet connection at a time as invariably the distance from the dump connection to one of my outlets would require more than a single length of sewer hose. I didn't feel like carrying 3-lengths of sewer hose. And if you are only staying at locations for 3 to 4 nights per, there's no labor savings with the Y set-up. For longer stays, or snowbirding down South, that's different.
38,773 PostsLatest Activity: Apr 25, 2026
