pnichols wrote:
Hmmm ... are you sure?
Yes. Mine's a 1998. A V10s had the 2 valve engine then, and all Ford Super Duty pickups and vans used the same 4 speed auto transmission (assuming they were automatic). I'm aware that later on the pickups went to a 3 valve engine.
As far as the F450/E450 comparison, the F450 is a much heavier duty truck, at least in the cab and chassis version. It has 19.5" tires, a larger rear axle, etc. Rear axle capacity is 12,000 vs. 9450. Engine and transmission should be the same. IIRC the E450 is similar in component specs to an F350 dually.
Here's some links to where I found the info on E vs F in your year.
F seriesE seriesSome light reading to go with your morning coffee. Enjoy!
