Mr_Mark1
Sep 12, 2018Explorer
The DEF coaches also have the DPF and regeneration cycles. We had no problem with our '08 Dynasty's DPF and regen system. It would regen once about every 8K-10K miles.
Our current coach has DEF and DPF and runs quite smoothly. No problems at all in almost four years and 45,000 miles.
Prevost has started putting electric fans on the side radiator (I think 7 fans) starting in the 2019 models. They will reverse as needed to push out debris/snow, etc. Very sophisticated.
MM.
MM.
38,766 PostsLatest Activity: Jan 10, 2026
