jtfcons
Aug 11, 2016Explorer
ricelake922 wrote:
How do I downshift manually when I have no buttons to do so as far as I know?
This is a joke, right??? Assuming you really don't understand how the transmission works in order to downshift you use the same keypad that allowed you to select "D" to get going in the first place. Simply hit another gear of choice 5,4,3,or 2 for example by hitting the down arrow. The engine management control will not permit a gear to be chosen that will overspeed the engine even if you choose 2 at 60mph. It is smart. Also be sure the engine brake or exhaust brake is on which will do the downshifting for you when the accellerator pedal is fully released.
38,766 PostsLatest Activity: Jan 10, 2026
