hershey
Jul 04, 2015Explorer
DP started overheating after a repair
2001 36' Fleetwood Expedition, 270 hp Cummin's and 5 spd Allison.
We are fulltimers, summer in WY and Winter in S CA. Last Nov just outside of Winslow AZ my radiator fan self destructed. Lost belts and fan pillow block. Repair facility had a hard time finding the correct parts and even the correct belts. After a week in their shop I was back on the road. Winter is cool but in May I found my first 90 degree weather on I-17 between Phoenix and Flagstaff. Started running a lot hotter than it has ever run.
I made it to Albuq with no real problem and thoroughly cleaned the radiator which I do as normal PM. BTW: Slobber tube is rerouted under radiator. Traded cars and now the new toad is 800 lbs heavier and traveling in 90+ temp, the MH still overheats on long grades.
My theory is: the repair facility replaced the fan with a different fan than the original and it isn't pulling enough air. I finally arrived at our summer destination and will do a more careful check of belt tention and number of blades on the replacement compared to the 9 blades on the old fan. I unhooked the toad on the last long grade today and it still overheats. I guess I'm looking for any other suggestions.
