Corkey05
Jan 10, 2015Explorer
DSDP Don wrote:This pretty much sums it up.
You're talking about three entry level coaches with small engines and the Allison 2500 transmission. The LaPalma and Vacationer started out as gas coaches and were elevated to DP's. Similar to the Fleetwood Bounder. It has traditionally been a gas coach and then they upgraded a few to DP's.
These are typically coaches priced at a level that allows gas shoppers to make that first step up into a DP. The Thor Palazzo would be another example.
Not every DP has a huge chassis. The majority are designed to tow 10K with some of the big boys being able to do 15K.
I remember looking at the first Vacationer DP and walked away disappointed. For a DP it lacked a lot of full features, like air brakes, air suspension & a Alison 3000 transmission, but it was still a DP.
The Alison 1000 it came with is a good transmission, but for the weight of this coach and a tow, it had it's limits.
Good try, but far from a home run ... might as well stay with a good gas rig that has all the same amenities, but lighter.
Vacationer Diesel Brochure
38,763 PostsLatest Activity: Dec 05, 2025
