ezgoinExplorerNov 19, 2020Draining hot water tankHi everyone, Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem. Thanks, BillShow More
wildtoadExplorer IINov 19, 2020I do know that Suburban states to drain the water heater when not going to be used for a while.
Related ContentGrey water tank won't drain completelyWater tank won't fillWater pump?Fresh water tank drain.House battery drain
