ezgoinExplorerNov 19, 2020Draining hot water tankHi everyone, Is it necessary to drain the hot water tank when the MH is sitting for several months between trips? I live in the SW so freezing temps are not a problem. Thanks, BillShow More
MitchF150NomadNov 20, 2020I did remove it just to check that very thing. It was completely drained and nothing came out the drain hole.
Related ContentGrey water tank won't drain completelyWater tank won't fillWater pump?Fresh water tank drain.House battery drain
