Old-Biscuit
Jan 12, 2014Explorer III
High humidity means more water is removed from air as it flows thru evap coil.
The condensation collects in a drip pan under the evap coil and then drains out thru couple drain holes in pan.
The water flows down the roof line OR there can be drain tubes connected to drip pan.
The drains are plugged and the drip pan is full and overflowing.
Have to remove roof shroud and then open sealed compartment where evap coil is.
Clean out the drains on drip pan.
38,766 PostsLatest Activity: Jan 10, 2026
