Executive45
Jan 12, 2014Explorer III
Most likely your filter is plugged up...when was the last time it was cleaned..?
When the filter is dirty, air cannot flow properly and the A/C ices up. That ice, as it melts then drips into the coach. There are two things you need to do..
First, to melt the ice that's formed, simply run the A/C on FAN ONLY for about 30-45 mins. That will get rid of the ice.
Second, clean the inside filter. While you're at it, clean em both....Dennis
38,766 PostsLatest Activity: Jan 10, 2026
