SooperDaddy
Jan 12, 2014Explorer
In addition to what Dennis said, it may mean one of 2 more things...a roof AC has a foam compression gasket that has to be snugged up to the roof on occasion with the bolts located inside the coach air return cover. Snug only do not get it too tight.
If that doesn't work plan "B" is to replace the gasket on the roof under the AC unit...best left to the pro's if you don't want to work on top of your rig.
The other possibility is that the drain holes on th roof AC unit are plugged with leaves or debris...meaning the roof AC units schroud needs t be removed and the drain pan holes cleaned out...again not an easy DIY task if you are unskilled!
Good luck!
Good luck!
38,766 PostsLatest Activity: Jan 10, 2026
