EMaznio
Jan 13, 2014Explorer
I got up on the roof and checked both units. The one that was dripping has some of its insulation on the inside of the shroud covering the cooling coils missing. There is outside air leaking in heavily in that unit, unlike the rear unit. I spoke to a local RV tech, who said that is likely the main issue. I don't have drain lines from the units, so those aren't the issue. The condensation is suppose to just drain off on the rooftop, which it is otherwise doing. After taking it apart and having it turned off for a while, it isn't dripping anymore. I sense that there likely was some ice buildup causing some of the dripping. I plan to wash my filters tomorrow too. Thanks everyone.
38,766 PostsLatest Activity: Jan 10, 2026
