wa8yxm
Jan 19, 2014Explorer III
jdart wrote:
what is happening ..u are running the ac on high ..need to run it on auto. This gives the unit time to recycle. This worked for me when I was in fl.
No, not the solution. HIGH/low/Auto only affects the blower.. You are best running it on HIGH, for several reasons.
ONE Running it on HIGH gives more drying action during compressor shut down. (Though there is one negative here.. Well Mixed here).
Two: Running it on HIGH your mind very quickly learns to filter the noise the thing makes so it's not nearly as bothersom as it is when on AUTO, not to mention the noise also covers (Blocks) other sounds from outside like the couple 2 sites over doing the knock down drag out thing.
Now the Mixed, which I already explained.
If the blower is running and the intake filters inside the coach are clogged it can suck water out of the drip tray to the area above the filter.. WHEN the blower STOPS,,, Niagara falls.
Of course this would happen on AUTO as well just you might not get as much falling water.
38,766 PostsLatest Activity: Jan 10, 2026
