PDXHiker's avatar
PDXHiker
Drive Train Repair Portland Metro area
I'm looking for some where that can do some work on my 2007 Four Winds Majestic i just bought. Driving it i feel like I'm floating all over and i would like to update the suspension, new Sway bar ETC. I am finding NO ONE in the area that does this work.  Camping world has still yet to return my call. RV county says they have a 10 year limit(this is crazy btw). can anyone point me in a good direction? maybe a shop you have used? Even other types of places i should call like heavy equipment mechanic shops?
Thank,
Mike
1 Reply
  • Before taking it in for suspension work, I would look at the inflation pressures you have your tires set at. What you describe, "floating all over" is a common symptom of tires being over inflated. Check the placard on the drivers side door for correct inflation specs as per Four Winds, and then set each tire's pressures to them. The maximum pressure info embossed on each tire from the tire manufacturer is not the correct inflation spec.
