glennts
Feb 14, 2015Explorer
Get yourself a collapsible shovel. You get stuck when your tires spin down in dry, loose sand digging themselves a hole. The front of the hole becomes like a tire stop that could be 6 - 8 inches high. Using the shovel you dig out the sand in front of the tires until you have a slight ramp so that you can drive forward where there will be little or no resistance instead of trying to climb up and out of the hole. And if you have enough water available, soak the sand in front of the tire to make it more firm. Also, if you spend any length of time on the beach make sure to frequently hose off that corrosive salt from the undercarriage.
