VA-Apraisr
Feb 24, 2015Explorer II
"yourtireshopsupply.com".......I ordered 10" brass one-piece extenders for inside dual wheel and "pig-tail" type for outer wheel. Do NOT use any of those braided line screw on extensions!! Mine came loose and broke off before. I have the tire shop mount these brass ones on and they work like magic. I air up/down at least 10 times a year, so needed something that would hold up. Make sure you also get the rubber O-ring support that goes into the chrome beauty-ring so your extender is supported in the hole securely. You may have to slightly bend the long extender to fit through the chrome ring but it will bend with slight pressure.
