Ivylog
Nov 04, 2016Explorer III
J-Rooster wrote:
I would back up the driveway!
You have less traction backing up.
OP, if you do not make it up and have to back down, let air out of your four rear tires... 100 down to 60 psi. This requires that you have found the air outlet under the front cap and have a air line long enough to reach your rear tires to air them back up once you make it to the top. You need to have this capability regardless as it's the easiest way to top off your tires.
38,782 PostsLatest Activity: Sep 02, 2026
