Effy's avatar
Effy
Explorer II
Apr 05, 2015
Drop receiver for towing CRV
Finished getting the baseplates on the CRV. Once installed it occurred to me that the baseplate is considerably lower than the receiver on the MH. Everything I have read says that the bars should be relatively level. So, I am in need of a drop receiver. Or am I? We travel with our bikes a lot so a while ago I got a dual receiver like this:
dual receiver
I've always had the bottom receiver used for towing and the top "extension" for the bikes. My thinking that the straighter the pull the better. But can this be used upside down? The "extension" piece lower to pull the toad and the main one then for the bikes? The one I have is rated at 4k pounds which is less than the crv.
The problem is that on the one I have it says:
upper tube for accessories and lower tube for towing
Which leads me to believe the upper one cannot be flipped and used for towing. Does such a thing exist? Or can I just tow as is with the bars not completely level?
Thoughts?
I did see this which allows a 4" drop and rise.
drop and rise
