jjson775
Apr 17, 2014Explorer
Dual wheel inflation
I am getting a new RV with dual wheels. I have a portable 120V Craftsman air compressor that has a fitting with a tab you flip to clamp on to a schraeder valve. Then you read the pressure on the compressor dial gage and run it until the tire is inflated. It works fine where you can clamp directly on to the schraeder valve.
Is there some kind of tool I can use with this same compressor to inflate the inside tires of a dual wheel RV?
