Cocky_Camper's avatar
Cocky_Camper
Explorer II
Jun 10, 2018
Duck brand foam filter for A/C
Has anyone replaced their Dometic A/C filter with the Duck brand foam filter from Wal Mart? The actually A/C filters are high. Replacement filters from most RV store that I’ve found are $3-5 with only enough to cut 1 filter. I can cut three out of these for $1. They are washable, but for $0.33, I figured I will toss after about 14 days of use, if they will work.
  • Yes the Duck Brand I have been using them for years. I change them out every month or sooner if need be.
  • I use the fiber glass home filter,just cut to fit.If it is good enuough for the house it will work with motor home.
  • I've cut my A/C filters from Duck or whatever similar brand Walmart carries for years. I do rinse them out from time to time, and usually get at least a couple of years from them.
  • Old-Biscuit wrote:
    I don't know about Duck Brand
    But I buy a big bag of foam filter sheet and cut replacement out of it routinely
    Return air filter is roughly 4" X 10" and I get probably 6 out of the sheet
    Been using it for 10 years
    Buy it at ACE Hardware
    Any foam filter material should work as well/better then OEM
    Key is 'clean' return air flow
    This is what I bought. It a little thicker which is why I was curious. Yes, I Er the key of clean air return. But I didn’t want to mess the a:c up if the little difference districted flow.
    https://www.duckbrand.com/products/weatherization/air-conditioners/24-in-x-15-in-x-25-in
  • I don't know about Duck Brand
