kalynzoo
Nov 25, 2015Explorer
The fresh water just dumps on the ground. I guess it would depend on where you are parked/stored as to attaching a hose for the drain. I've never had an occasion where dumping onto the RV pad represented a problem. It is fresh water and it either runs off into the grass or down the normal water channels. Naturally you don't want to flood your neighbors campsite. But you really don't need to drain the fresh water too often. When traveling your water weighs in at about 8lbs per gallon.
