Bordercollie
Nov 25, 2015Explorer
Most RV's have a spigot on the side to dump fresh water tank, They also have two separate "low point" drain valves inside the RV, that you must open to drain the hot and cold water lines. You must close the low point drain valves completely, after draining, or fresh water pump will not shut off with pump switch "on". When draining the low point drains you should see water dribbling out of two small tubes under the RV.
