Bailey_Travis's avatar
Mar 05, 2014
Dynaquest Owner Opnions
I have a Airstream Interstate 24' and want a larger RV. I'm very interested in the Dynaquest models. I don't want a 40' but maybe 34-36'. May I ask for Dynaquest owners' opinions as to build quality and any problems you would call attention to? Also, if I buy used what's the best way to get it checked out to determine it's true condition. Thank you for your replies!
  • Might want to ask in Super C forum:
    http://www.rv.net/forum/index.cfm/fuseaction/listings/forum/23/days/14/sub/26.cfm
  • I can tell you from owning a new RV every one or two years, I finally found a keeper. The Dynamax coaches are very well built, woodwork, plumbing, electrical, soundproofing, I would put it at the top of the list. I have only seen a few problems with the new DX3 I guess you get what you pay for.
  • Dynaquest uses top quality materials and components, but the quality control from the factory is a bit on the weak side. Freightliner chassis is very good. Buying a used motorhome with the bugs worked out is the best way to go.
    Ride, handling and mileage are the best in the industry.
  • Ivylog's avatar
    Ivylog
    Explorer III
    Stay away from one on a F550 as it's kind of hard to get the cab off when you need to work on the engine.
  • Don't think you're going to get much in the way of responses. By my count there are only one or two guys on here with a Dynamax.
