Bordercollie
Feb 04, 2022Explorer
E-450 Stuck on Defrost Mode
I suddenly have cold air coming through defrost vents only, not through dash vents. Defective parts are buried behind firewall on engine side, not accessible without much complicated disassembly. A number of You Tube how-to videos show an easy "bypass" replacement of vacuum hose, check valve, etc., fix to restore normal AC vent control. Ignoring the problem allows loss of vacuum and affects proper engine operation.
I'm hoping that a local RV repair shop can do the easy bypass repair at a reasonably small cost.
