- DrewEExplorer IIAlternately, you can just realize that a hot water heater is the heater for the hot water system, just as the engine block heater is the heater for the engine block and a space heater is a heater for the space enclosed in a room.
One may equally well ask why residential hot water heating systems (not potable water heaters, but hydronic room heating) have what is generally called a "boiler" even though the water never ever reaches a boiling temperature.... - pnicholsExplorer III guess it depends upon what "hot" means to a person.
If a water heater's control is set to maintain it's water contents at say, 122 degrees F, and it's temperature sensor kicks in the heating mechanism (propane flame or electric resistance coil) whenever the temperature of the water inside the tank sinks down to around say, 119 degrees F ... then I guess the RV'ers "hot 119 degree water" is being heated hotter to bring it back up to the control's set temperature of 122 degrees.
Note that of course a water heater cycles on and off to maintain the water in it "to around" the set temperature of it's control ... so the (hot) water inside the tank actually varies between two "hot temperature" conditions.
Hence ... what we have is a water heater that spends a lot of time heating water that is "already hot"". That's why I call the water heater in our RV mostly a "hot water heater"!
(Navy RV'ers can call it what they want. :) ) - Dusty_RExplorer
pnichols wrote:
Desert Captain wrote:
Thanks, guys for clearing that up. I usually learn something new almost every time I log in.
Growing up with a Navy Master Chief for a father I vividly recalling him making many corrections... One of my favorites that this Forum often reminds me of regards water heaters.
Every time I ever said "hot water heater" he would explode... It is not a hot water heater, it is a water heater. If the damned water is hot you have no need to heat it!
Seriously dad? I guess it was a Navy thing. LMAO!
:B
Well ... as a lowly ex AF guy ... who am I to bash the Navy.
HOWEVER, a water heater is indeed a hot water heater if one keeps it turned on all the time so as to all the time keep the water in it hot that is already hot. ;) and :B
My question is. How do you heat hot water?
You heat cold water with a water heater. - pnicholsExplorer II
:B
HOWEVER, a water heater is indeed a hot water heater if one keeps it turned on all the time so as to all the time keep the water in it hot that is already hot. ;) and :B - Desert_CaptainExplorer IIIThanks, guys for clearing that up. I usually learn something new almost every time I log in.
:B - pnicholsExplorer II
Phil, when we bought our coach used from La Mesa RV they told me it had a 40-gallon tank. It was showing nearly empty and when I went to the gas station it took 50 gallons. That pinned the needle on the gauge and I don't think I have ever gotten that much in again only because I never let it get that low. When I called Nexus and asked for the specs from the original sale it showed the 55-gallon tank the original owners opted and I assume, paid for.
Are you saying your E-450 does not have an AC water heater? I thought all of the Ford Class C's came with them. :h When we do have an electric hook up {which is not all that often} I always run ours on AC and save my propane for heat and cooking.
:C
Drew E answered pretty well your inquiry regarding power for our Class C's hot water heater.
Our rig uses an Atwood 6 gallon propane powered hot water heater that is common in many RVs. This hot water heater does not have on it the option for use of 120V AC power heating, instead of propane heating.
A propane-only hot water heater has never been a problem for us because it heats it's 6 gallons so fast and it's insulation keeps the water hot for long - that we can keep it turned off most of the time - so it's propane use on camping trips is trivial.
HOWEVER ... should we ever have a propane system failure when out and about in our Class C ... having this hot water heater option would allow us to get by in our RV nicely with only the Onan generator and the Ford's 55 gallon main fuel tank. - DrewEExplorer II
:C
Ford doesn't install any sort of water heater in the chassis; that's installed by whatever company builds the RV. (The E450 chassis may just as well be destined for a box truck or ambulance or shuttle bus as for an RV, and those have no need of a water heater.) Many, many class C's, especially older ones and/or those with 30A electrical systems, have gas-only water heaters, regardless of the chassis on which their built. Mine is one of them...though it's built on an E-SuperDuty chassis, before they decided to call the model the E-450. - Desert_CaptainExplorer IIIPhil, when we bought our coach used from La Mesa RV they told me it had a 40-gallon tank. It was showing nearly empty and when I went to the gas station it took 50 gallons. That pinned the needle on the gauge and I don't think I have ever gotten that much in again only because I never let it get that low. When I called Nexus and asked for the specs from the original sale it showed the 55-gallon tank the original owners opted and I assume, paid for.
:C - pnicholsExplorer II
My 55-gallon tank takes 55 gallons... No amount of "topping up" changes the physics of the tank. Since I prefer to drive on the top half of the tank and rarely if ever let it get below one quarter where the generator won't run if needed I avoid getting lower than that at all costs.
As always... Opinions and YMMV.
:C
I'm not sure what I've noticed in our E450 is related to the physics of the tank. I suspect that it might be related to the evaporative emission control system Ford uses in their Series E vans.
If it is as I suspect above, I get around the Ford system's filling limitations versus gas station fuel pump vapor sensing shutoff systems ... by trickle filling to get the last 5-6 gallons into it's supposedly 55 gallon ... tank.
I have to do the same thing on my GMC pickup and our Lexus sedan in order to get all of the gallons of fuel into their tanks that they say they hold in their specifications. I wonder if this "never really full" problem might be widespread in the vehicles that we - in at least the U.S. - drive.
I like plenty of onboard fuel in our Class C whenever heading out into the middle of nowhere, and an additional 5-6 gallons to reach a true 55 gallons of course helps - especially if unexpected long generator runs turnout to ever be needed.
I consider our large fuel tank along with our built-in Onan generator - if ever needed to when not on hookups - heat our coach, cool our coach, power it's refrigerator, pop our popcorn, deep fat fry our fish and chips, and cook our other food by powering a hot plate and the microwave. I only wish that we had one more electric feature in our Class C to complete this no-hookup emergency self-contained picture -> a water heater that is both propane powered and 120V AC powered. :S - Desert_CaptainExplorer IIIMy 55-gallon tank takes 55 gallons... No amount of "topping up" changes the physics of the tank. Since I prefer to drive on the top half of the tank and rarely if ever let it get below one quarter where the generator won't run if needed I avoid getting lower than that at all costs.
:C
38,707 PostsLatest Activity: Jan 05, 2014
