VintageRacer
Nov 05, 2014Explorer
On the trucks at least the camber and caster is adjustable within a small range by rotating a sleeve with an off-center hole. There are different sleeves available that each have a different range of adjustment. Since one sleeve adjusts both camber and caster at the same time the effect is often a compromise.
Brian
Brian
38,782 PostsLatest Activity: Sep 10, 2026
