I was about 150 miles into today's return trip home from the Oregon Coast when all of a sudden the motorhome started lurching a little bit. My first thought was fuel pump, but the 460 FI was running ...
I would suggest getting another good check on the transmission fluid level. Also, check the engine oil and coolant levels. Something funky is going on, and it might be an overfilled tranny at this point (if you're lucky). However, even that can cause harm to the E4OD. I would be hesitant to drive it more than to the nearest transmission shop unless I could determine a cause for the exhibited abnormalities.
