Desert Captain wrote:
"I did not use tow/haul mode except in some severe situations."
That's too bad as the non use of Tow Haul is hard on the trans {it runs hotter}, and hard on the brakes as they are needed far more than with the proper TH use. Every Class C renter {at least a dozen}, I have spoken with was never told about using Tow Haul. Just another reason I will never buy a former rental unit.
As always.... Opinions and YMMV
:C
Please explain how running in tow haul increases the trans temp. It would seem to me that the opposite is true. Certainly the engine runs at higher rpms and burns more gas. If you drive easy, you don't need to ride the brakes. I experience much better performance running my Expedition without tow/haul.
Thanks
