I got my 1994 28' GBM pursuit for $2000. It needed a lot of work to make it ready to camp. So I got to work. Re-sealed the roof(big job). Replaced the roof top a/c unit. Had the front & side windows tinted. Tore out all of the flooring and carpeting, and installed new carpet and vinyl tiles. Steam cleaned all of the upholstery, smells fresh now. Repaired some of the plumbing and electrical in various places, under the cabinets and under the dash. Installed a KVH automatic satellite dish and all the wiring required to make it work. Installed an inverter for dry camping(watching tv without running a generator). Repaired dash a/c, replaced water pump, all belts and hoses, thermostat, flushed radiator, etc. Built a new, heavy duty trailer hitch and welded it to the frame(I also had the 3500# rated hitch, thin & cheesy). Replaced all batteries, and found a deal on some craigslist 225/70/19.5 tires. Built a spare tire carrier on the rear(did not come with one). Replaced shocks & sway bar bushings. This is most of it, i'm sure there's a few things i'm missing. It was a ton of work, but now I have something i'm proud to drive and know the in's and out's of. If something goes south, I can probably fix it on the spot. I probably put about $4k into it to make it road worthy.
