"holstein13".....You keep saying that you activated the features like they were programmable somewhere. Is that what you mean or that you just started using the features that were already there? I don't know if the King Aire has some cruise control features that are different than my Dutch Star.
My Dutch Star has a two speed engine brake that works with my cruise control. Once I set the speed on a grade, with cruise control, and turn my engine brake on either HIGH or LOW, they will engage once I exceed the set speed by about 5-6 mph. If the speed continues to rise, I'll move the engine brake from LOW to HIGH. If it still picks up speed, the trans will down shift and the unit will start even heavier braking.
What I just described is standard on the Freightliner XRC Chassis at the Dutch Star level. Does yours do something different than that?
