True_temper
Mar 01, 2017Explorer
I wouldn't think about a trip without a spare. I have trouble getting around but I still change 22.5 tires. It's not that much work if you know how, some people are lazy and never had to work hard. Get t a torque multiplier and you can get the nuts off. The biggest problem is getting the bead set. I have had to use ether and a propane torch when all else failed. Now I cut 2x4 block and put between the bead to train the tire bead apart.
