DSDP_Don
Dec 06, 2014Explorer
"holstein13".....Economy Mode on your King Aire will be of very little value. In reality, it only helps coaches that are underpowered. If you have a coach with a enough power that can run through rolling hills in 6th gear, using Economy Mode won't change anything.
Some of the older coaches with 275 HP to maybe 330 HP may benefit slightly by holding a gear longer on a grade. Even then, I doubt that you would ever see a measurable mileage increase.
38,769 PostsLatest Activity: Apr 03, 2026
