wolfe10
Dec 08, 2014Explorer
gemert wrote:wolfe10 wrote:
I am not so sure the Mode Button can be "programmed to do different things"-- at least in the RV application. But if someone finds out there is, would be very interested in what other things it can be programmed to do.
It CAN be reset (Allison shop) so that the default is Economy instead of Power. That is an easy one.
Sorry I wasn't clear. What he was referring to was reprogramming so shift points were more custom to what each person wanted. I'm sure there are limits but as a "pull out of my ...butt... kind of example, they could program it to perform better in a 1/4 mile drag race if you wanted it. My wife complains all the time about my unrealistic examples, sorry!
Indeed shift RPM's can be changed-- but the change would affect all shift points/all gears. And it would not involve the mode feature.
Said another way, you can not change JUST the 5-6 shift. Attempting to do so would affect all shifts. Basically one of the perimeters tell the Allison ECM the correct operating RPM range of the engine.
38,769 PostsLatest Activity: Apr 03, 2026
